else
if Variable SUCCESS Equals TRUE
if Variable SUCCESS not Equals Cancel
Run Program $TARGETDIR$\\foxhhelp7.exe /RegServer
I could register it manually myself after installing the application using Run, Cmd and typing the foxhhelp7.exe /RegServer line.
What you have done should work fine, however for VFP 7.0 the foxhhelp7.exe and the foxhhelpps7.dll should be placed in Common Files\\Microsoft Shared\\VFP and in Windows\\System32. You should Register both the exe as in your example and the dll from the system32 folder.
Jim Oswell
Greenway Health, LLC
http://greenwaymedical.com
