IIS and Virtua Folder
mqk
Post by mqk »
During the installation, I created Virtual Folder on an existing WebSite using its index. The Site index is stored in a variable called $SITE_INDEX$, and the the code for creating Virtual Folder as follows:
Create Virtual Folder "TEST" in IIS Site #$SITE_INDEX$, pointing to physical location $TARGETDIR$
But unfortunately, on uninstallation I'm not able to delete Virtual Folder, which has been created on installation. The code is:
Delete Virtual Folder "TEST" in IIS Site #$SITE_INDEX$
On uninstallation, I found that the variable $SITE_INDEX$ is empty!!
Any help?
Thanks in advance
sinan
Post by sinan »
Just read the site index again upon uninstall.
mqk
Post by mqk »
I tried many time to read the Site index but I couldn't, I got an empty variable.
The idea is, we have different website, and then I choosed one to create Virtual Folder. So on the uninstall how can I get the same site index that I used on install, please can you explain with a piece of code.
Thanks in advance,
sinan
Post by sinan »
I assume you are reading the site index when installing? Just copy-paste the same code into the part where you do the uninstall.
Also, if you are creating new sites as well, you may use a hard coded site index.
