Version 7?
Version 7?
What's new in Version 7 and when is the release date?
Some of the improvements we've made to InstallAware since version 6.0:
Automatic Vista Certification: InstallAware 7 produces MSI packages which are always "Vista Certified" logo compliant, regardless of how you author your setup. Forget about rules, test cases, and software validation suites. InstallAware 7 gets the job done for you automatically - every time.
New Application Runtimes: InstallAware 7 provides full support for the latest application runtimes, including .NET 3 and SQL Server 2005 with Service Pack 2. As promised, our team continues to deliver instant updates for new technologies from Microsoft within 48 hours of their release.
Enhanced Group Policy: You asked for it, and we listened. InstallAware 7's updated Group Policy Wizard produces single file MSI's which can be used for Group Policy deployment, or work equally well stand-alone. You may now also deploy patches using Group Policy, and your MSIcode script has new variables for use with Group Policy deployment.
Large Setups: InstallAware 7's setup engine has been optimized to support rapid execution of setups containing tens of thousands of lines of MSIcode script. There are also no longer any limits on the number of files you can include in your packages. Builds are nearly twice faster than before with optimizations to the compression engine, especially on multi-core systems.
Vista Aero Experience: Only InstallAware 7 allows you to build software installers which contain custom Glass regions. Impress your end-users right from the start - jazz up your dialogs with Glass and Flash animations!
InstallAware 7 officially launches on 7/7/7.
Stay tuned for more info.. Very soon!
Panagiotis Kefalidis
Software Design Team Lead
Wooot. 2007-07-07
I am looking forward to IA7~
Gizm0 wrote:Some of the improvements we've made to InstallAware since version 6.0:
Edhy, as far as i know there are scheduled updates on these sections for the 7.x series but i'm not sure if they are going to be available on the first release.
But the way, 7/7/7 is not a random date.. It's the date where the new 7 Wonders will be chosen
@Edhy:
Why dont you call the Update Setup yourself?
You just have to include this line somewhere after "Apply Install" (if its succeeds of course)
"Run Program $UNINSTALLLINK$ /updatesetup"
(i have put in "if Variable NEEDSUPGRADE Equals FALSE" before, so that the Update Setup only starts when you do a first time Install).
Works perfect for me.
hth, Stefan
hth, Stefan
Version 6 and version 7 are completely different. Version 7 is a major upgrade thus, current customers have a special discount if they upgrade between major versions. If you upgrade to version 7 though, you'll get all 7.x series updates for free as you did on 6.x series.swarovski wrote:Do IA 6.x customers eligible to upgrade to version 7 without extra cost?
But I purchased IA6 on 2007-05-08.Gizm0 wrote:Version 6 and version 7 are completely different. Version 7 is a major upgrade thus, current customers have a special discount if they upgrade between major versions. If you upgrade to version 7 though, you'll get all 7.x series updates for free as you did on 6.x series.swarovski wrote:Do IA 6.x customers eligible to upgrade to version 7 without extra cost?
It's been less than 2 months only.
Is IA 6.x will still have future version upgrades after IA 7 is released?
The current download link in
http://www.installaware.com/downloads-p ... nloads.htm
only showing the latest version of IA.
There will be 2 separate download links later?
You have to discuss your issue with Candice. She's the one in charge for sales. I can't answer these questions unfortunately. The thing i can answer, is that any time a new major version is released, no feature updates are released for previous version except for security reasons OR issues that turn the product unusable.swarovski wrote:But I purchased IA6 on 2007-05-08.Gizm0 wrote:Version 6 and version 7 are completely different. Version 7 is a major upgrade thus, current customers have a special discount if they upgrade between major versions. If you upgrade to version 7 though, you'll get all 7.x series updates for free as you did on 6.x series.swarovski wrote:Do IA 6.x customers eligible to upgrade to version 7 without extra cost?
Thanks Gizm.
Gizm0 wrote:You have to discuss your issue with Candice. She's the one in charge for sales. I can't answer these questions unfortunately. The thing i can answer, is that any time a new major version is released, no feature updates are released for previous version except for security reasons OR issues that turn the product unusable.swarovski wrote:But I purchased IA6 on 2007-05-08.Gizm0 wrote: Version 6 and version 7 are completely different. Version 7 is a major upgrade thus, current customers have a special discount if they upgrade between major versions. If you upgrade to version 7 though, you'll get all 7.x series updates for free as you did on 6.x series.
If its been less than 3 months since your purchase, your upgrade is free. If for some reason your account is not automatically upgraded to vend v7 licenses, just drop us an email, and we'll take care of it for you. Be sure to enclose your original purchase confirmation email.
And minor upgrades are perpetually free (with version 6, we served free minor upgrades for nearly 14 months). However we do not support old versions once a new major version has been released.
