Manual compression
jbbad
Manual compression
Post by jbbad »
Hi.
I build package as uncompressed directory layout.
Can I compress this layout to single exe manually?
Step-by-step instruction will be great ;)
If you want to manually compress files, then InstallAware cannot do it for you - not sure why you asked for step by step instructions here in that case :)
You probably want to use a third party tool that can create self extracting EXE files, and run your setup.
Let us know if you find a third party tool with better compression rates than InstallAware!
