Target Folders
OKuma
Target Folders
Post by OKuma »
With InstallShield, you can specify [WindowsVolume] which represents the root of the windows boot drive. What is the Pre-defined path for the Windows Volume with InstallAware.
OKuma
swarovski
Re: Target Folders
Post by swarovski »
OKuma wrote:With InstallShield, you can specify [WindowsVolume] which represents the root of the windows boot drive. What is the Pre-defined path for the Windows Volume with InstallAware.
OKuma
Get Folder Location System->Windows Directory into WINDIR
I can use this to obtain Windows directory.
WINDIR will store C:\\Windows
You need to get C: only?
You can try Special -> Boot Path, or System -> Windows Directory and then call an Extract Path -> Extract Parent Drive on the return of that value.
