Call static method in a .NET dll
dcockrell
Post by dcockrell »
I am using install aware version 6.6 and am wondering how I would call a static method in a .net dll that returns a string. I am prompting the user for some database connection information and need that to be encrypted via our encryption routines.
Don
MLS
Post by MLS »
You could pass the parameters to an exe after the dialog to save your connection information.
Or the way we do it is launch a configuration program after install since we do the same thing we encrypt the data in a file on the system.
If you need to cancel the setup because they havn't configured the connection then you can use a return code from the exe to indicate that they cancelled
Having it during install is nicer though
dcockrell
Post by dcockrell »
Yeah, that should work. It's not ideal for other reasons, but I can do that. Like you said, it would be nicer if we could call it from the install.
thanks
