Delete Files usage
Ryan Lee
Delete Files usage
Postby Ryan Lee » Wed Jul 04, 2007 5:54 pm
When my application runs it creates some files in the target directory (myFile1.txt and myFile2.txt). When uninstalling I want to delete those files. I am currently trying the following with no success.
DEFINE REGION: Perform Uninstallation
 if Variable REMOVE equals TRUE
   Delete Files $TARGETDIR$\\myFile1.txt (when uninstalling)
   Delete Files $TARGETDIR$\\myFile2.txt (when uninstalling)
   Apply Uninstall (get result into variable SUCCESS)
   Set Variable PROGRESS to 100
 else
Postby MichaelNesmith » Thu Jul 05, 2007 2:23 am
There's a help file article on this in the help file, titled setup commands preceding apply uninstall. That will help you.
get101
Postby get101 » Thu Jul 05, 2007 6:00 pm
It goes in as part of the install section rather than the uninstall section.
Look for this line:
 Comment: TO-DO: Insert any additional install commands here
and put your delete lines there.
Ryan Lee
Postby Ryan Lee » Thu Jul 05, 2007 6:40 pm
Thanks, I got it working.
Users browsing this forum: Baidu [Spider] and 132 guests
