InstallAware 7.01 Update
Post by CandiceJones »
A free update to InstallAware 7 is now available on the public web site (and the customer account). If you are affected by any of these issues, please upgrade. If not, you may keep your existing version:
1) Automation DLL caused errors during unload
2) The IDE would not shut down automatically during a log off
3) LOADOLDDATA compiler variable behavior was broken
4) Multi-Instance support for Web Builds was broken
5) App pool names were not created correctly, this affected XP customers
To upgrade:
a) Install the latest trial version from the public website
b) If you are a licensed user, just regenerate and reinstall your license
Note that unless you are affected by #1, you can skip step (a) above and quickly install the "patch" for your product by regenerating and reinstalling your license.
