How do I stop debugging?
wileywilly
Post by wileywilly »
I upgraded to version 7 recently and I think am most impressed by the UI. One problem though - I cant seem to get my setup to stop debugging .
When I cancel the setup (in debug mode running within the ide) the dialog freezes. Am only able to close the dialog from the task manager.
Has anyone experienced this or am I doing something wrong?
Are you clicking the setup wizard dialog that is showing away? If its a wizard step, you need to click the Next button (or another button that returns from the dialog to abort debugging).
wileywilly
I have tried clicking the dialog away but it still doesn't go away.
This only happens when I click on the cancel button - next and back buttons do exactly what they ought to do.
Am using scripts I built with version 6(they run ok in v6)
Can't reproduce. Anyone else seeing this behavior?
wileywilly
How do I stop debugging - SOLVED.
I finally solved the debug issue - my setup script contains a call dll function which informs the host application that setup is finished therefore passing control from the setup to the host application.
My code during the 'dialog freeze'
[DEFINE REGION: Process (Un)Installation]
label: Main Install
Comment: Exit Setup if Wizard Loop cancelled
if Variable WIZARD Equals CANCEL
Call DLL Function $APP_REGISTER_DLL$->EndInstall (get result into variable CallDLL_CHECK)
Terminate Installation
I changed the code so that the call dll function comes after the Terminate Installation command
The CANCEL button now does just that - It cancels setup
Thanks for your help and keep up the good work
