GPO not working
ddebono
GPO not working
Postby ddebono » Sun Jul 15, 2007 5:34 pm
Had problems with IA and GPO with 6.6 and upgraded to 7.0.
The problem is still there. When running manually it works like a charm, but when using GPO and machine install it does nothing.
I can see that it's running when starting up Windows XP, but no files are copied in. Some other setups we have made works, but some others dont, and we cannot figure out why.
This was the reason for bying IA, and if this is not solved quickly we have no option but to use the money back guarantee.
Update:
Found out that only the last setup program executed using GPO is working. All of them seem to be run, but only the last one does anything. Another strange thing is that the setups seems to be applied after login even though they can be seen executing on startup.
Please help!
Users browsing this forum: No registered users and 97 guests
