New Theme: Swoosh Dialog Theme
sinan
Postby sinan » Sun Sep 18, 2005 7:01 am
A new setup theme is available for InstallAware! This theme displays a very nice swoosh animation during the installation progress of your setups.
The Swoosh Dialog Theme has been generously donated by Cyberspace HQ, makers of AddWeb (http://www.cyberhq.com).
You may download the installer for this theme here:
http://www.installaware.com/swoosh%20dialog%20theme.exe [2.0 MB]
This theme installer will:
    1) Install all the files for the Swoosh Dialog Theme
    2) Create a shortcut in the Start Menu for the Swoosh Dialog Sampler
You may then use the Swoosh Dialog Theme in all your InstallAware setups. You may also run the Swoosh Dialog Sampler to check out the dialogs. Users of InstallAware Studio may customize this theme further using the Dialog Designer (and make their own themes from scratch).
This is a great theme! Clean and compelling. Swoosh Dialogs offer a compact yet appealing design, making them great for use with all types of setups.
Return to “Sample Scripts”
Users browsing this forum: No registered users and 8 guests
