if statement that works in debug but not in run
Ryan Lee
Postby Ryan Lee » Fri Jul 20, 2007 5:50 pm
I have the following statements:
Set Variable ISSERVICERUNNING to
Check Service State for MyService (write result into variable ISSERVICERUNNING)
MessageBox: $TITLE$, service: $ISSERVICERUNNING$
if Variable $ISSERVICERUNNING$ Equals RUNNING
  MessageBox: $TITLE$, in if block
When I debug with MyService running, I get a message box stating that the service is RUNNING and I go into my if block (pops up another message box).
When I run with MyService running, I get a message box stating that the service is RUNNING but I do not go into my second if block (no message box stating i'm in the if block).
Postby MichaelNesmith » Fri Jul 20, 2007 6:16 pm
The IDE already warns you about this (unless you turned tips off), but don't use $ signs in fields where variables are already expected:
is wrong;
if Variable ISSERVICERUNNING
is correct.
Ryan Lee
Postby Ryan Lee » Fri Jul 20, 2007 7:55 pm
My bad copying the code into this post.
if Variable ISSERVICERUNNING Equals RUNNING
It doesn't actually have the $ signs around the ISSERVICERUNNING in the if block.
It does not work.
Postby MichaelNesmith » Mon Jul 23, 2007 5:37 am
I created a simple script like this:
Check Service State for Themes (write result into variable TEST_SERVICE)
MessageBox: Testing Service, $TEST_SERVICE$
if Variable TEST_SERVICE Equals RUNNING
  MessageBox: Test service..., is running!
Which works exactly as expected.
Users browsing this forum: No registered users and 80 guests
