This problem has only been observed on Windows Server 2003 x64. It runs fine on XP (32-bit), other OS's have not been tested. This can be reproduced using the "default project" sample project that is distributed with IA.
To reproduce this problem do the following:
1. Install the application
2. re run the installer from the executable
3. In the maintenance dialog select add/remove features, press next
4. do no change any of the settings and press next
5. wait at the confirmation dialog for 10 min and then press next
6. after the completion dialog is displayed, some error messages are displayed indicating that an error has occurred. I have attached screen shots of the error dialogs. Other than the error dialogs, the installation appears to be updated properly.
If you do not wait for ~10 min in step 5, the error does not happen and everything runs normally.
