support for installing com+ application
denv95
Postby denv95 » Tue Sep 20, 2005 2:36 pm
I am evaluating your product. Does it support the installation of COM+ Applications? Currently I am manually creating them using Component Services.
sinan
Postby sinan » Tue Sep 20, 2005 3:14 pm
Unfortunately, not at this time. You may manually create registry entries required for the application, but we do not have this process available automatically as yet.
denv95
Postby denv95 » Tue Sep 20, 2005 4:00 pm
OK, thanks for the quick reply. That, in itself, is refreshing.
ErikB
Postby ErikB » Mon Mar 06, 2006 7:59 am
Sinan,
Do you have a walkthrough available for including the installation of a COM+ application in your installation project? That would help me (and likely others) a great deal.
Erik
Postby CandiceJones » Mon Mar 06, 2006 4:20 pm
Dear Erik
I will try and see what I can dig up for you!
ErikB
Postby ErikB » Tue Mar 07, 2006 3:32 am
That would be brilliant! Thanks Candice :-)
Erik
micke314
Postby micke314 » Wed Feb 28, 2007 8:19 am
Hi!
This thread has been kind of quiet for a while.
Just wondering if anything has happened with regards to COM+ in the last year or if there are any plans for the future?
regards
/Micke
Return to “Non-Technical”
