Writing to the registry
I have some information I need to write to the registry, but I need to do it before Apply Install. Is there a command to do this?
I think there's a "Registry Direct" plug-in on the Plug-Ins section of the forum. That'll directly execute the registry action, by-passing Windows Installer.
You'll have to manually remove the entry therefore, before or after Apply Uninstall.
Or, you can call Apply Install multiple times - whichever works for you. Each call will execute a full install routine though.
Users browsing this forum: No registered users and 77 guests
