Environment Variables not set on Windows 2003 Server
rlangham
Post by rlangham »
On Windows 2003 Server 64-bit the Environment variables are not set properly. If after running the install, you open up a new CMD prompt, you will see that they are not set. If you go into Control Panel / System / Advanced / Environment Variables, they are specified correctly there. Press OK and then open a new CMD prompt and they are there correctly.
I had this issue with another installer also, to resolve, I had to do a
PostMessage(HWND_BROADCAST,WM_INICHANGE,0,"Environment")
This notifies Windows of the change.
I attempted to do this with Call DLL Function and not having much success. i I tried different combinations of trying to pass the values
HWND_BROADCAST = 0xFFFF = 65535
WM_INICHANGE = 0x1A = 26
User32.dll ->PostMessageA and also User32 -> PostMessage
e.g.
double word = 65535
double word = 26
double word = 0
poniter to string = "Environment"
also tried variations using Long, etc.
Ideally, InstallAware should take care of this after any Environment updated, but trying to find workaround for now.
Ron
ckaware
Re: Environment Variables not set on Windows 2003 Server
Post by ckaware »
Hello Ron,
Did you ever figure this out? :-D
Chris
