In my project I detect if the installation machine is running Microsoft Message Queuing and if not then it runs a batch file which I have that installs\\configures MSMQ from the add/remove windows components automatically.
This batch file runs absolutely fine when run directly on a machine (XP) but when running it from my installation project the batch file attempts to run but fails with the message
"The application could not be initialized."
Even if I do not actually include the batch file as a support file in my project and try an execute it from within the project I get the same problem.
Any thoughts?
Kind Regards
Chris
Different results when running batch file through v7.0
Tesseract_Support
Tesseract_Support
Tesseract_Support
Tesseract_Support
