I tried to check wether a program (WIBU-Box Resource kit (hardlock dongle software)) is already installed or not and I therefore used the following line in my script...
Get Installed State for {00060000-0000-1004-8002-0000C06B5161} into variable WIBUBOX
...but this somehow doesn't work. The result in WIBUBOX is false, even if the Resource Kit is installed with the above Product Code (GUID). I have already tried serveral different notations for the GUID (with and without brackets and/or hyphens). I'm currently using InstallAware version 6.22.
Is there any mistake or bug or any other solution for checking if a program is already installed?
