Version of Windows Installer used...
[MS]Mark
Postby [MS]Mark » Wed Dec 08, 2004 7:35 am
Just doing some more testing and I have some merge modules from Crystal Reports that bring up an error saying 'Requires a MSI 1.1 Database'. Also, the MSI database validation reports that the version is 1.
Is there anyway of getting a newer MSI database/installer used?
sinan
Postby sinan » Wed Dec 08, 2004 7:43 am
InstallAWARE uses/requires/installs MSI version 2.0. The databases all include the additional tables that are available in version 2.0 and above.
I am not sure why you are getting this error. If you let me know where I can download the Crystal merge modules which are raising this error, I can investigate the issue further.
[MS]Mark
Postby [MS]Mark » Wed Dec 08, 2004 7:54 am
'Merge Modules for Crystal Reports 10 RDC Deployments' under http://support.businessobjects.com/fix/ ... les.asp#02
I'm using the runtime and reportengine MSMs.
It's odd as other Install creators I'm testing don't have a problem - only InstallAware.
sinan
Postby sinan » Wed Dec 08, 2004 9:11 am
Thanks, I'll investigate and get back to you.
[MS]Mark
Postby [MS]Mark » Wed Dec 08, 2004 11:55 am
Seems it is a known issue with the reportengine MSM:
http://support.businessobjects.com/libr ... 013575.asp
edit - all works OK now...thanks for the help :)
sinan
Postby sinan » Wed Dec 08, 2004 1:36 pm
I just spent 2 hours clawing my way through this...with no resolution, so I am very glad to hear the problem is not in InstallAWARE :lol: Strange though, because you did explicitly mention that other tools worked fine with it :?:
Users browsing this forum: Google [Bot] and 38 guests
