How to remove duplicate Web Media Blocks?
rbrodt
Post by rbrodt »
Hi NG,
Not sure how this happened, but I appear to have created a duplicate Web Media Block. Is there any way to remove this, or do I simply set the "Do Not Build" flag and leave it alone?
neillans
Post by neillans »
What edition of InstallAware are you using?
If you are using one that has the script editor, simply delete the offending duplicates.
Andy Neillans
rbrodt
Post by rbrodt »
Andy,
Thanks for the reply. Unfortunately, I have the Express version which, I'm finding out, was probably a mistake. :cry:
neillans
Post by neillans »
Ah. I'm sure if you submit them to support they will tidy it up for you :)
Andy Neillans
