Creating new controls for the dialog editor
Is there a way to add custom controls to the user interface editor? Basically what I want to do is have a control for selecting computers on a network but there does not appear to be anything like this in the list of available controls. Also I cannot find anywhere where the available controls are documented. For instance the control PTShellCombo1 has default options such as 'ptscoAutofill' where is the documentation that tells me what this does and what other options are available?
You can use only available controls. The available controls are not documented because all of them are standard controls from windows and they work exactly the same. For example, here is a screen shot showing you the functionality of a PTShellCombo control.
Alejandro Ronquillo
We don't have any documentation about the controls. What we can do is, if you have any question about a control functionality, you can let us know and we will clarify your doubt.
Alejandro Ronquillo
Users browsing this forum: No registered users and 55 guests
