Newbie Question - features
Bo Andersen
Post by Bo Andersen »
Hi all,
Can anyone share thoughts on best ways to accomplish this...
I need to install a web-app
My setup includes a small webserver but if user has IIS installed I need to give a choice between installing to IIS or to the included webserver.
Thought of using the features-feature (can you say that?), but that gives me the choice of none or both as well as one or the other.. So it's a mutually exclusive thing...
Should I just create a new dialog to ask and present this only if IIS is installed?
Bo
Alex_Ronquillo
Post by Alex_Ronquillo »
That's what I would do. I would check for the presence of IIS. If it is installed, I would ask the user, (with a custom dialog), whether to include the Web-App in IIS or install the Web server included in your installer.
Alejandro Ronquillo
