$WINSYSDIR$ not working
cmclendon
Postby cmclendon » Thu Oct 06, 2005 11:42 am
I am using the Second Edition build, and when using the .NET Framework 2.0 template the version checking was not working. I inserted the following code to check the result:
Get File Version $WINSYSDIR$\\mscoree.dll into Variable MSCOREVER
What I got back was 0.0.0.0
However, if I change it to a hard coded path:
Get File Version c:\\windows\\system32\\mscoree.dll into Variable MSCOREVER
I get back the expected version.
Is this is a known issue?
sinan
Postby sinan » Thu Oct 06, 2005 5:09 pm
Please make sure $WINSYSDIR$ is initialized beforehand.
Easiest way: search for WINSYSDIR in the script (type CTRL+F and type in WINSYSDIR), then copy-paste the line that initializes it right above your call for the runtime.
sinan
Postby sinan » Thu Oct 06, 2005 5:23 pm
Note: The sample script already performs this initialization for you. Please double-check that you did not accidentally delete the code (or are overwriting the variable later on).
Users browsing this forum: No registered users and 40 guests
