How can i store/use a value selected by sql statment from sql server. the SQL goes some thing like this...
"SELECT DB_VERSION FROM TBL_VERSION"
now i want to use the the value of the field "DB_VERSION " selected by SQL and use it in the installer. But i am not being able to use it.
I have also tried using this
SELECT $CURRENT_VERSION$ = DB_VERSION FROM TBL_VERSION
Where $CURRENT_VERSION$ is declared in the Installer.
But not being able to access the value selected. How to do it?
How to access value selcted by SQL Script in the installer
Re: How to access value selcted by SQL Script in the install
You can create an sql script that writes data on a .txt file to a temp directory and read the content you want (return values) from there, for example, line by line.
Panagiotis Kefalidis
Software Design Team Lead
Roostar2004
