My download URLs contain a compiler variable that is the version number (incl. dots).
I can download the files over the web without problems, but from within the setup
I get a dialog that the download broke up and whether to resume are retry. None of these
options work, though, and the same dialog appears again and again.
I took into consideration case-sensitivity but that's obviously not enough.
Any ideas?
Thank you.
Are compiler variables allowed for paths to web media blocks
Alex_Ronquillo
pfennig
The compiler variable is defined in InstallAware Project Settings | Compiler variables.
E.g. build_version = 3.5.03.
The web media path is like
http://www.domain.com/packages/productn ... ckage.7zip
The setup is created manually or eventually via a FinalBuilder run were the actual version
is given in the parameter list.
pfennig
