Use Special Folder inside Installation script
itfraggel
Post by itfraggel »
Dear all,
is there any list for which constant is which special folder?
I will install inside a installation some files into CSIDL_COMMON_APPDATA,CSIDL_COMMON_DOCUMENTS,CSIDL_PERSONAL,etc. Which constants i should use for that? Or how can i make that possible in the installerscript?
Thanks for your help
pfennig
Post by pfennig »
You can use Get Folder Location to do that. There you can assign many different
system folders to variables which you then can use in your further script.
Some might already be defined in the Define Setup Globals region.
