Wish list
pfennig
Wish list
Post by pfennig »
- the UI Editor should save the position of its windows (and placing a window at position
0;0 is awful; some people have their Taskbar at the left or top of the screen)
- the ObjectInspector should have a combo-box at the top where one can select another component
- the Alignment Palette should be open if it was open when UI Editor was closed
- the Localization Wizard should assume the Export path as Import path automatically at
least as long as a project isn't closed. Remembering the last Export path would be nice to
- when creating a new project from a template IA should remember the parent of the target directory
or allow the customization of some general settings, like a default project directory
- the build log window should be resizable and have a save button
- using a variable as Product Name should write the value of that variable to the Control
Panel - Add/Remove Software entry, not the variable name including $$
I know there's more, but for now this should suffice ;)
