Add a predefined folder into 'Target Folder'
rumman
Post by rumman »
The project (.mpr) I am working on does not include predefined folder $TARGETDIR$ under the "Target Folders" list. Although, the script deifnes $TARGETDIR$ as $PROGRAMFILES$\\$TITLE$. How can I add $TARGETDIR$ under "Target Folders"?
Alex_Ronquillo
Post by Alex_Ronquillo »
Would you send a screenshot of that? TARGETDIR must be in the "Target Folders" However, you can specify the same in the script with the "Install Files" command.
Alejandro Ronquillo
rumman
Post by rumman »
Thank you Alex. A screen shot has been uploaded.
I have to install quite a number of files, so would prefer a drop-down method, rather than typing all of the filenames. Thanks again.
Alex_Ronquillo
rumman,
your attachment didn't make it. Please attach it again.
Alejandro Ronquillo
rumman
Post by rumman »
In case the attachment does not work again, may I email it to you?
rumman
Post by rumman »
Solved it. I have set one file name using "Install Files" command and then $TARGETDIR$ appeared on 'Target Folder' screen. Thank you.
