How do you link the action of a 'browse' button to variable?
soeinz
Post by soeinz »
I have 2 separate paths that need to be selected in the destination dialog of my installer. I have duplicated the edit and browse button for the TARGETDIR and modified the edit control to link to a different variable. My question is how do I make the second browse button action change the new variable. I've tried setting its action to 'Select Custom Folder' but I cannot see where you set what the custom folder is and when I do this the second browser button does nothing (and the first, oddly enough, modifies both edit controls)
Alex_Ronquillo
Post by Alex_Ronquillo »
This is accomplished by setting the "Writes values to Variable" to the name of the button you pasted. See attached screenshot for an example.
Alejandro Ronquillo
soeinz
Post by soeinz »
Great thanks, worked perfectly
