I have a problem in deploying crystal report for a .NET application.
I have used the following merged modules...
1.Crystal_Database_Access2003.msm
2.Crystal_Database_Access2003_enu.msm
3.Crystal_Managed2003.msm
4.Crystal_regwiz2003.msm
5.VC_User_CRT71_RTL_X86_---.msm
6.VC_User_STL71_RTL_X86_---.msm
And have edited the "Crystal_regwiz2003.msm" with orca and changed the value in ModuleConfiguration->DefaultValue to the registered value found in my .NET IDE.
But after installing in a fresh mechine when i try to open the report I get the following error....
"Cannot find KeycodeV2.dll, or invalid keycode"
Is there anything I am doing wrong or missing anything? Thanks in advance..
Arup..
How to: VS Crystal Reports MSM Installation w/ License Key
I have been able to find out the solution. I have done 2 things while editing "Crystal_regwiz2003.msm" with Orca.
1. In the table "ModuleConfiguration" I have edited the "DefaultValue" column with the lisense key of crystal report(In case it is integrated with .NET it will be available from the help-> About Microsoft Developement Environment).
2.In the "Property" table provided the same key in against "CRPIDKEY".
This has solved my problem.
