Post build events?
Mateo
Post build events?
Postby Mateo » Thu Aug 30, 2007 1:24 pm
Does InstallAware have any post build event type functionality like VS or InstallShield does?
I'd like to be able to copy my installer onto a network drive after it has been built and being the lazy person that I am I'd like it to happen automagically when I hit the build button. :D
If this isn't possible from within the InstallAware GUI, is it possible to build the installer from JScript or a batch file?
Thanks!
Alex_Ronquillo
Postby Alex_Ronquillo » Thu Aug 30, 2007 2:10 pm
In the design tab, goto "Deployment"-->"Build Settings"
In this screen setup the output fields. You can direct your build to any drive in your network.
Alejandro Ronquillo
Mateo
Postby Mateo » Thu Aug 30, 2007 3:44 pm
Thanks for your quick reply!
That doesn't exactly work for me because there are other files and folders in the folder I want my installer to go after it's built.
If I use a custom output folder and point it to Z:\\Installers\\MyApp\\ for instance, the final installer ends up in Z:\\Installers\\MyApp\\Release\\Single\\. If I were to place the files I need in \\Release\\Single\\ they will be deleted during the build process.
Thanks again.
Alex_Ronquillo
Postby Alex_Ronquillo » Thu Aug 30, 2007 4:45 pm
Read Building from the Command Line in IA help contents. You should be able to build from a batch file.
Alejandro Ronquillo
Users browsing this forum: No registered users and 123 guests
