Is there a function to create a recursively directory layout like
$DBLOCATION$ = c:\\database\\application\\sql that he would automaticaly create
c:\\database
the $DBLOCATION$ could be different because of the user input from the form.
recursiv directory create
Alex_Ronquillo
Just use the "Create Folder" MSI command.
When you write:
If C:\\Dir1 does not exist, it gets created along with all other folders until Dir4 is created inside Dir3.
When you write:
Create Folder C:\\Dir1\\Dir2\\Dir3\\Dir4Alejandro Ronquillo
