How to detect SQL Server
How can we detect if user has installed any SQL Server 2005 or SQL Server 2005 Express? And if not SQL Server 2005 Express is installing.
I have the same problem. User have installed SQL Server 2005 , when the instalation process starts, instalator wants to install SQL Server Express- for what? ;/
I don't know how to overcome this problem- I don't know what to do to detect SQL Server 2005
My aim: if SQL Server is detected, SQL Server Express won't install
Any ideas what should i do ?
All you need to do, is to check if HKEY_LOCAL_MACHINE/Software/Microsoft/Microsoft Sql Server/ key exists. If it does, a version of Microsoft Sql Server is installed. To Check if 2005 is installed, you need to check for HKEY_LOCAL_MACHINE/Software/Microsoft/Microsoft Sql Server/90 Key. If exists, then SQL Server 2005 is installed OR a version of SQL Server 2005 Express.
Panagiotis Kefalidis
Software Design Team Lead
