Is there a way to create folders (in Windows Vista with files inside) under the C:\\Users\\All Users folder? I believe this is the equivalent of the old Windows XP C:\\Documents and Settings\\All Users
In the Files section I only see the $MYDOCUMENTS$ folder option.
Any suggestions are appreciated.
Thank you
Peace in Christ
Marco Napoli
http://www.ourlovingmother.org
Create folders under C:\\Users\\All Users in Windows Vista
sdeschenes
Marco,
In the Design view, go to the Files section and in the bottom left hand box, right click on Target Folders and click on Add System folder. In the drop-down list, select System->Application Data Directory. There is a checkbox that says "If applicable, use the common folder shared by all users." Select that option and IA will create a folder called $ALLAPPDATA$ which is the same as C:\\Documtents and Settings\\All Users.
