How does Create folder work?
zonique
Postby zonique » Mon Oct 24, 2005 4:25 am
I have a very simple problem: How do i create the folder "c:\\cap"?
I've tried just about anything now, with no luck :(
I use Create Folder, but none of the below creates the folder
Create Folder c:\\CAP
Create Folder c:\\\\CAP
Create Folder c:\\\\CAP\\I've also tried creating the folder in $TARGETDIR$ and some of the other predefindes dirs, with same result
sinan
Postby sinan » Mon Oct 24, 2005 6:41 am
You just need to make sure you are testing after Apply Install. Nothing will happen until Apply Install is called. This is unfortunately a Windows Installer limitation.
zonique
Postby zonique » Tue Oct 25, 2005 3:35 am
Ahhhh I used Create Folder after Apply Install.
Moved it up before Apply Install and it works like a charm, Thx :)
Users browsing this forum: Bing [Bot] and 25 guests
