A customer used our InstallAware to install our product. They entered the following custom directory for installing:
c:\\cprogs\\Test\\ Folder
The install finished without error. The problem is that Windows won't allow you to have leading spaces in folder names. So it created:
c:\\cprogs\\Test\\Folder. The desktop shortcut had the above path with the leading space in it, which doesn't work.
Is there a way to remove the leading spaces in the path?
problem with new folder with leading space
I figured out a way to remove the leading zero.
I created the following loop after the wizard loop:
Works great!
Label: Lead_Space
if Variable TARGETDIR Contains "\\ "
Replace "\\ " with "\\" in variable TARGETDIR
Goto Label: Lead_Space
Works great!
Users browsing this forum: No registered users and 100 guests
