hi!!
i put a question again:
- I need know if i could put in a field one variable which "call" a file what i do, i need the variable has a passwd value. I have make the file with the passwd and i need that variable to comunicate with this file.
thanks!!
i have a question again...
Alex_Ronquillo
I guess you are asking about reading a password from a text file. If that's the case you can just use the "Read from Text File" command. That command allows you to get text from a file and put it in a variable.
Alejandro Ronquillo
