- IA web version available from web-site does not install product correctly... there is download of about 50Mb and then dialog disapear without a warning
- Main web-site does not have a link to a full packet download (it is visible only from www.installaware.com).
- Will be nice if there were an ability of having a total size progress bar (component count, or full size) and progress of particular step (as it is right now)
- I am doing localization for Russian - how to extract onle language from translation manager and import/export it to share
Few comments and questions
Serge Dosyukov
Serge,
The translation files are in the trans folder in your IA installation folder. You can extract them there.
The main IA website is www.installaware.com. In general, you should try to download materials from the IA website, and not www.mimarsinan.com as that tends to lag behind a little.
Sinan
Sinan
Serge,
I checked the current web downloads and they all seem to work fine - I tested on two different machines, each edition, one VMware, another real, for a total of six tests.
If you still have problems with web media block downloads, please try to provide reproducible steps so we can investigate further.
Sinan
Sinan
I did install from a full install and it will be ok for now.sinan wrote:If you still have problems with web media block downloads, please try to provide reproducible steps so we can investigate further.
Before this I did try to use web-install... 2 times...
- download and run setup from local drive
- go to personalized
- do not change anything
- click next and start installation
I think it did fail when installing runtime support. I am not sure how elso to reproduce it - might be it is just my end...
Do you have support for restore connection (if there is a line problems?)
It is appear what download is starting each time from the beggining if broken...
Serge Dosyukov
Each setup has a unique theme and also a unique title, so you should have been able to see which one it was. Which site did you download from? Even the page on mimarsinan has text links for each edition.
Broken downloads are normally resumed - unless your internet cache folder is set to too small a size, and/or you are not allowing the caching of internet downloads.
Also, if you are using proxies etc., the downloads should automatically detect them and succeed in that case as well.
http://www.mimarsinan.com/installaware.asp has link only to a webinstall.sinan wrote:Each setup has a unique theme and also a unique title, so you should have been able to see which one it was. Which site did you download from? Even the page on mimarsinan has text links for each edition.
Sorry I didn't find download section. Main site has a full version as well as web one. I did try one from mimarsinan when tried to install.
I am not using proxy on this computer in particular, as well as mine home one.sinan wrote: Broken downloads are normally resumed - unless your internet cache folder is set to too small a size, and/or you are not allowing the caching of internet downloads.
By the way, at home computer installation went ok.
Serge Dosyukov
