Posible to do case insensitive compare?
zonique
Post by zonique »
Hi
Doing my install I need the user to type in some information into a textbox and then compare the text with some text from a text or from the registry, ignoring the case of the text.
Normally I would just convert both strings to lowercase, before comparing, but I dont see a command that?
sinan
Post by sinan »
I believe you can use the Parse String command for this purpose. It has a flag that ignores case. So you could easily compare your strings.
