Hi guys,
We are migrating our products to windows and evaluating InstallAware for the installation...
All of our components are mutually exclusive, but each can be installed multiples times.
I have seen the components dialog but that does not stop the user from selecting multiple components. Is there a way (say a radio button components list) that forces the user to only select one component?
Also, is there an option/process that allows the user to run the installer again and again to install the same component/feature to different locations?
Thank you!
Mansoor
exclusive features
For the first question, yes just build a custom dialog!
For the second question, it sounds like you want to use multi-instance installations, there is a sample that describes how to do this.
