Updating only web media blocks
TMacy
Postby TMacy » Thu Oct 11, 2007 3:06 pm
We have application A, which references web media blocks B and C.
Two weeks later, we want to update media block B, but there is no change required in application A. If I update B (same filename, etc), and the user reruns the original setup for application A, will it detect the updated web media block B and install it?
If not, what do I have to do to get the new B installed on the user's box?
jimo
Postby jimo » Sat Oct 13, 2007 8:23 am
When you build the setup again it will generate a New web media block b and also a new setup.exe, if you plave the new files with the old files when they run the update setup it will uninstall the old product and install the new product. If this is no the desired behavior then you will need to create a patch.
Jim Oswell
Greenway Health, LLC
http://greenwaymedical.com
TMacy
Path?
Postby TMacy » Sat Oct 13, 2007 9:04 am
Does a patch cause the rebuild of B? Or does it generate a single .exe that has the updated parts of B?
jimo
Postby jimo » Sat Oct 13, 2007 9:39 am
I belive it creates a single exe with the patches to the files in your installation.
Jim Oswell
Users browsing this forum: No registered users and 120 guests
