I'm using IA V6.22 and I want my Setup to install an existing SQL-Server Database (mdf/ldf-file are present) to a local SQL-Server 2005 database system. I have already managed to create a new database by integrating a new (empty) MS SQL Script and checking "Create database if absent". Then I tried to generate a SQL-Script that contains the whole database layout (tables...) and the whole content, but that seems a little bit too complex and inefficient to me.
Is there an easier way to add an existing SQL-Server Database to a (local) SQL-Server using the IA Installer, e.g. by copying and somehow adding the mdf/ldf-files to the (locally installed) SQL-Server instead of transforming the whole database into a script?
Thanks in advance...
How to install an existing SQL-Server database?
You can restore your DB from the mdf/ldf files with a restore script. Here is an example:
RESTORE DATABASE [DBName] FROM DISK = '$SUPPORTDIR$DBName.BAK' WITH REPLACE, MOVE 'DBName_Data' TO '$Path$\\DATA\\DBName.MDF', MOVE 'DBName_Log' TO '$Path$\\DATA\\DBName.LDF'
Alejandro Ronquillo
Thank you! That was exactly what I needed.
I created the DBName.BAK file with the backup function of the SQL Server Management Console. Then I added it to the Support Files in IA and completed the script as follows, so that I don't overwrite any existing database:
IF NOT EXISTS(SELECT * FROM sys.databases where name = 'DBName')
Users browsing this forum: Google [Bot] and 172 guests
