installing support files
Ryan Lee
Postby Ryan Lee » Fri Oct 19, 2007 12:53 pm
Is it possible to install the support files, or do something to get the same effect?
Currently I have a support file that needs to be run during the pre-requisite installation and I also want this file installed at the target location. Currently, I have this file as a support file and as the source for an install file command. I think the source file is being copied twice.
Alex_Ronquillo
Postby Alex_Ronquillo » Fri Oct 19, 2007 1:19 pm
As I explained you in http://www.installaware.com/forum/viewtopic.php?t=3103. you can just copy the file from $SUPPORTDIR$ to $TARGETDIR$ with the "Copy/Move Local Files". Remember this command must be used before the "Apply Install" to take effect.
Alejandro Ronquillo
Users browsing this forum: No registered users and 111 guests
