Uninstall before Reinstall??
lightz
Postby lightz » Fri Nov 02, 2007 2:34 am
Hi again,
I noticed that if i reinstall an existing application using the same installer, it doesn't uninstall before installation.
However, if i reinstall using another build (different Revision code) it uninstalls, then reinstalls.
Can i code it in the way that packages with the same Revision Code goes thru an uninstallation process as well??
Postby CandiceJones » Fri Nov 02, 2007 3:40 am
Sure, you could do that. Just read your setup's MSIcode - the prereqs section - and take out the test and/or condition for the previous version, to do the uninstallation always.
Return to “Non-Technical”
Users browsing this forum: No registered users and 124 guests
