is there any way of defining other values for the day and time comboboxes in the update_setup_schedule Dialog?
Cause Sunday 3 AM is not o time where our customers will have there PC`s turend on
And if someone doesnt change the preset values, he will never get notified that an update is available.
I tried to set the UPDATE_DATE and UPDATE_TIME variables in the update script, but this doesn't change anything.
In the "Define Interactive Characteristics" Dialog its also not possible to set a variable in the "receives information" field, cause it seems that this feature isnt working with comboboxes.
would be great if you can give me some advice to make this work!
(as Sunday 3 AM are not the values with index 0 in the list of values, i think there must be some way to influence that).
A second problem with the /updatesetup mechanism is, that the once set date/time is not preserved if the updatesetup is started the next time. (other values like choosing only to notify of updates, or directly download and install them are preserved, so i also hope that the date/time could be preserved to).
Hope this is all possible, so i can make my customer happy
thnx for answering, Stefan.
