mqk
Posts: 18 Joined: Mon Aug 15, 2005 7:57 am
Post
by mqk » Thu Nov 03, 2005 6:21 am
Hi
During the installation, I need to convert the input text to lower case. Is there any way to do it?
Thanks in advance,
sinan
Posts: 1037 Joined: Sat Nov 13, 2004 8:12 am
Post
by sinan » Thu Nov 03, 2005 8:49 am
Would restricting the input to lower case only help? If so, replace the Edit control on your dialog with a MaskEdit control. Then, set the CharCase property of a MaskEdit control to ecLowerCase .
mqk
Post
by mqk » Wed Nov 09, 2005 8:18 am
Where can I find MaskEdit? Currently I have EditFile plug in.
sinan
Post
by sinan » Wed Nov 09, 2005 1:43 pm
Its not a plugin - its a dialog control that you can place on your dialogs using the dialog editor.
