The started program after installation does not see files of
santey
Postby santey » Sat Nov 10, 2007 4:54 am
I have created the project in your program and
Has established in the end of installation dialogue
Window "finish" with an option " Run $Title $ now ".
Then I compiled the project and have started.
In the end of installation of the program to me has appeared
Dialogue window "finish" and I have chosen an option
To start the program.
The established program was started, but
The program does not see files of parameters in
It каталаге though it is started from this
The catalogue.
In what there can be a problem???
Alex_Ronquillo
Postby Alex_Ronquillo » Tue Nov 13, 2007 6:40 pm
Santey,
Please elaborate a little in the problem, I did not really understand it.
Alejandro Ronquillo
Mateo
Postby Mateo » Fri Nov 16, 2007 11:51 am
I think what you are saying is that when the application is run from the installer it can not find its configuration files. If that is the case, it is probably because the current working directory is not what you think it is. When the installer runs the application, the app inherits the installers cwd.
It would be nice to be able to set the cwd when calling the Run Program function but I *think* (please correct me if I'm wrong) you can set it by calling the Run Program As instead.
Users browsing this forum: No registered users and 138 guests
