Hi all,
I was wondering if there is any way to check if a select folder/drive is a removable drive?
I have a dialog which allows the user to select a backup location, ideally this should be a removable drive and therefore I would like to check this before enabling the Next option.
Thanks in advance for any help,
Sinead
