UnInstall SQL Express
arupkrdas
Postby arupkrdas » Wed Nov 14, 2007 1:36 am
Does any body know how to uninstall SQL Express Instance while uninstalling the application. In MSDE it could be done with the Product key of the Installed verion for that Instance. Is there any way out in SQL Express where by I can uninstall only the Instance that i have Installed.
arupkrdas
Postby arupkrdas » Thu Nov 29, 2007 12:46 am
The command to uninstall SQl Express is ...
Install SQL Express (command line: /qb REMOVE=SQL_Engine INSTANCENAME="$INSTANCE_NAME$", get result into variable SQL2005)
only problem i am facing is that unlike installation where SQL Express used to get installed silently, here the Window is popping up and one can press cancel.
Alex_Ronquillo
Postby Alex_Ronquillo » Thu Nov 29, 2007 10:32 am
arupkrdas,
Change the /qb switch for /qn:
Install SQL Express (command line: /qn REMOVE=SQL_Engine INSTANCENAME="$INSTANCE_NAME$", get result into variable SQL2005)
Alejandro Ronquillo
arupkrdas
Postby arupkrdas » Thu Nov 29, 2007 11:09 pm
Thanx a lot Alex_Ronquillo...
Users browsing this forum: No registered users and 112 guests
