Attach database in Windows Vista
dhouse
Postby dhouse » Fri Nov 16, 2007 5:32 am
I am using IA7 to create an installer that needs to attach sql database to sql express. The installer works well in Windows 2003 and XP Prof but the database fails to attach in Windows Vista.
Below is the sql script that i use:
USE [master]
GO
CREATE DATABASE [TEST] ON
( FILENAME = N'$TARGETDIR$\\DataFiles\\EEMS2007.mdf' ),
( FILENAME = N'$TARGETDIR$\\DataFiles\\EEMS2007_Log.ldf' )
FOR ATTACH
GO
Is there any advise from the IA team?
Gizm0
Postby Gizm0 » Fri Nov 16, 2007 4:29 pm
Verify that the MSSQL.1 (default instance folder) is accessible from the user you're trying to make the attach.
Panagiotis Kefalidis
Software Design Team Lead
dhouse
Postby dhouse » Sat Nov 17, 2007 2:15 am
The data files are created on the $TARGETDIR$\\DataFiles\\ and not the default locations (which i am not sure how can it be done). I have assigned Everyone to Read and Write permission to this folder $TARGETDIR$\\DataFiles.
I can manually attached the files using SQL studio management express. Is there anything else that i miss out?
Users browsing this forum: No registered users and 114 guests
